higher rev
higher rev
do the mx3's have a governor or a rev limiter on them and if they do where are they and how can i take them out if they dont how can i change my gear ratios so i can top out my gears.i have a 94 1.6 dohc fun little car
Re: higher rev
im no mechanic but its their to help ur motor i'd keep it(my 2 cents)
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
Re: higher rev
mine did not have a governer but there is a rev limiter its there to keep you from damaging your engine.. and it kicks in well past the peak power point anyways
-torp.
I don't own a Mazda.
Re: higher rev
thanks for the infor since i wont do that is there anyway to change my gear ratio because it seems like 3rd and 4th are a little power less
1st is good and so is 2nd ive tried searchin for som infor but no luck so if you guys could help me out that would be great
racing all the time
tuner
Re: higher rev
how high can you rev the 4 cyl? ive never gone much over 6000 rpm. anyone??
dont drink and drive....you might spill your drink.
- Shady469
Re: higher rev
with both the SOHC and the B6T i've seen 6,400.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Pearl-JapSpec
Re: higher rev
mine revs past 6500... but wit loss of power i can get to almost 7k in 2nd
Car Out Of Order For Now...
2 weeks In counting till re-incarnation!!
New G-Force Front Bumper!!
-_-_-_- Pics On Site -_-_-_-
http://members.cardomain.com/mx3_junkee
Re: higher rev
yeah my rev limit kicks in at 6500... well used to till i swapped motors.
-torp.
Re: higher rev
i like my 7300(in ecu) redline in my mx-3 with my bp but in my car the tach relines at 7500, i guess the tack is off a bit
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
sw-ontarioguy
Re: higher rev
with my 95 dohc 1.6 4 banger, i've reved it to 7200, which is where the rev limiter kicks in and the car losses all its power. (no i didnt do this on purpose, i was in 1st gear a pretty lil hunny walked by lol)
Speed Kills....Save a life...Drive a HONDA
Re: higher rev
dont know about a rev limit but my 94rs cuts off at 105 mph Tried a few times to get past it but it just cuts out
Matt
94 Corvette Torch Red RS---SOLD
http://www.cardomain.com/member_pages/view_page.pl?page_id=307456
Timmyd865
Re: higher rev
I'm sorry to say this, You'll all hate me, I have the 95 b6ze, and the red line is 6500. I know (this is why you'll hate me) but I redline it at least 3 times everytime I drive it
My engines soon to be toast, which is why I'm rebuilding it. I want a high reving NA, So i think i'm gonna do high CR pistons, over bore a smidge, aggressive cams, port polish, and finish off my exhaust w/custom headers (i'm workin on making right now, FRIGGEN HARD, 2nd attempt) I hope to have a more lively engine is all. Auto X is my key goal here. Buty yeah, B6ze, the revlimiter is 6500. Cya
16" Sport Edition Fox 2's, Yokohama H4's, Eclipse CD player, Eclipse components, MTX amp, Lightning Audio woofers in a custom fiber glass enclosure, custom intake, factory spoiler installed, reverse indiglo gauges, custom switch panel<p>
www.geocities.com/timsmx3
maldo
Re: higher rev
6500rpm is hardly a high reving NA engine. The stock valvetrain isn't capable of higher rpm, that is one of the reasons for the limit. If you are wanting a high reving engine why not get a BP? Start from a better level and go with a set of solid lifters and stiffer springs. There is more to getting higher revs than just a p&p and an overbore. The valvetrain needs to be designed around your goal. If you want 9500rpm the odd time you will have to invest an easy $1000+ just for the valvetrain (ie. valvesprings, solid HLAs, better cams, ti retainers), everything has to be light weight with lots of pressure to resist valve float. To top it all off, you need a new ecu, standalone is a must. I would even suggest getting the crank knife edged to reduce reciprocating mass and friction. It is much more costly to build a B6 or BP in NA form to hit 9000rpm with a possible outcome of about 140-170whp than it is to build a FI engine with an output of 250+whp. Expect a minimum investment of $10000, engine alone. Hardly worth it and it won't be streetable.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
