Trans Axle
ScAb BoY
Trans Axle
Post by ScAb BoY »
How do i get the tans axle out i have everything unbolted the pass. side drive shaft is still on the transaxle i thought that i could just pull it out but it's not that easy!!! how do i dropp the trans axle any tips
Thanks,
Dakota
If It goes fast enough to kill me or do somthing stupid on it then, I want IT!!!!!!
http://www.cardomain.com/id/streetfighter101
Ogimoj
Re: Trans Axle
Post by Ogimoj »
Just keep pulling. For some reason, the shafts on the mx's are the biggest pain to pull out, plus there's no real good spot to pry against.
