NOOOOOOOO (@&%ing Idle!!!!!!
- cjthor
Just got my car back from corksport and the friggin idle problem is back. We checked the battery and its fine, the alternator is putting out 14.2 volts and I reset the TPS. Why is it back!! Maybe it just never left!! Now its really bad. Used to do it only once in a while and now its almost every time I start it. We REALLY need to figure this one out. When I get home tonite I am gonna put in my other IAC valve and see if that works.......any other ideas???
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
Re: NOOOOOOOO (@&%ing Idle!!!!!!
off topic-<p>jarid, john has the piece you're looking for. i gave him all that stuff when he picked up the motor.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- guyaverage
Start off by cleaning the IAC you have on there now. Mine didnt APPEAR that dirty (as much as I could see), but even after 8-10 good soakings with carb cleaner it was still draining black. After it started to drain clear solvent, I wiped it and dried it, put it back on, adjusted the idle speed, reset the ECU, and a month later the idle is still rock solid. Not that this is the problem with yours, but I think the majority of people having this problem a simple IAC cleaning would work wonders.
"The answer is: More power. I dont care what the question is."
-Tim Allen
-Tim Allen
what i did was raise my idle to around 800-950 *750 is the stock idle speed for both MTX and ATX* and then i just turned on my rear defroster and the idle is SOLID.. i turn on my rear defroster every time though.
- team slideways
- team slideways
- cjthor
I will try the IAC thing tonite. I have a spare so I will just swap it. I am pretty sure the idle screw is set correctly and I dont think turning on the rear defroster is a good fix for engine problems. I'm not baggin on you marsh but I dont think that this would solve my problem
Jarid Perry
- cjthor
Well the IAC checks out ok, the TPS is set correctly and still got the prob..
Jarid Perry
just try it its one push of a button its not swapping out an intake tube.
- team slideways
- team slideways
think he wants a properly working car, not a jimmy rig...
92 red rs
performance exhaust
zx2 struts and Eibach springs
turboed + stand alone when the cash is there
- cjthor
Well I screwd with it a lil more. I think now that I got it back from corksport it has another prob. The idle was waaaayyy high and then kicked into the up and down idle. I adjusted the idle down with the idle screw and then loosened the TPS. I kinda played with it til the idle problem got as good as it was gonna get. It is still there but you barely notice it.<p>[ April 28, 2003: Message edited by: cjthor ]</p>
Jarid Perry
I think al this talk about the mysterious idol problem has jinxed me, as yesterday it started to happen to my car! However, I've notice it only happens when the car is cold, when I start the car first thing in the morning and I have the clutch depressed. If I let the clutch out, it the engine dies down to around 700 RPM. Any ideas?
I saw a street sign yesterday that said Caution! Children playing! so I slowed down. Then I thought Wait! I'm not afraid of children!
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by marshmallow15:
what i did was raise my idle to around 800-950.<hr></blockquote><p> <blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>I am pretty sure the idle screw is set correctly[/QB]<hr></blockquote><p>you're welcome.
- team slideways
- team slideways
- cjthor
Before all this crap was goin on my idle was at 750. Corksport must have either turned it way up or I have a vac leak causing the car to compensate by raising idle. The up and down thing is still there but its not as bad as it was.
Jarid Perry
my idle was crazy only when i drove it hard n then braked hard i got new wires new plugs new cap new rotor n it runs like a dream
- 93-Spec-Edn
I read somewhere a bad clutch switch may cause idle problems. Does your rpm change when u r stopped and put it into 1st or anyother gear?
also a part called the BAC valve can cause it (this is big bucks).
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
my idel is low and it will go almost to zero when i press the cluch.Every time i break it will almost shut off the clock and the radio .It ticks me off.All that happens while i am driving and every few sec. or when i press the break it will happen
