Overheating
ramon
Overheating
Post by ramon »
My car was overheating when not in motion. I fiqured out that one of my radiator fans was bad. Sould i buy performance fans? If so where?
papa roached
Re: Overheating
Post by papa roached »
check your thermostat
cjthor
Re: Overheating
Post by cjthor »
One of your fans? What year is your car? Only one fan should kick on when it gets hot. The other fan is for the A/C. I would check the thermostat as well. Have you done any work to the car lately? Drain the coolant lately?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
MX3chicago
Re: Overheating
Post by MX3chicago »
read in "FAN ISSUES" i solved the problem pretty easily and good
