BULLFROG Big Bore Throttle Body (1.6L 4cyl)
what does it do different from the stock throttle body and is it worth the money?
Re: BULLFROG Big Bore Throttle Body (1.6L 4cyl)
i believe your stock throttle body is 55mm. Gude bores it out to about 59-60mm's. You won't notice any real difference without other major modifications to your motor (like nitrous or turbo). <p>Not worth the money
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Its worth it if you are a highly modified car. If you have intake and exhaust then it wont be worth it, if you have it decked out with turbo, standalone computer, etc then it would be woth the price.
