Throttle bodies
- papa roached
Throttle bodies
what throttle bodies will bolt to my 1.6 SOHC that will let it get more air? (if there are any)
Manach
Re: Throttle bodies
If you would have done a search.. you would have found the Rx-7 MAF.
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
Re: Throttle bodies
He was asking for a throttle body not the MAF.<p>Don't think you can swap any into the MX3. Although I could be wrong.<p>Corksport sells a bored out throttle body made by bulkers.
Think it's like $250, not sure you would see any gains.<p>www.corksport.com
Stop the rave.... I wanna get off!
Manach
Re: Throttle bodies
Oh meep..<p>Well, a speed shop could bore it too..
Manach
Ruben MX-3
Re: Throttle bodies
wuts a MAF?.... i forgot
BP POWERED MX-3
http://members.cardomain.com/bbprecidia
- Casino
Re: Throttle bodies
Mass air flow.
