Gear change?
Gear change?
went to look at the car today seems fine except there's a load of play in the stick when in gear is this just a linkage or something more serious. And more importantly is it costly to fix, the cars costing $800US for a 1991 with 75K on the clock and all the trimmings>
'92 MX3 1.8 V6
G-MAX 40mm lowering springs
'91 AZ3 1.5 35mm drop +V6 stryt brace.
- papa roached
Re: Gear change?
mine was the shifter bushings, changed them and its all happy now
