4 cyl to V6
- papa roached
4 cyl to V6
what are the differences in the engine mounts, will hte v6 mount up to the same mounts in the 4cyl?
- cjthor
Re: 4 cyl to V6
No it does not. There are some big differences. I would not recommend trying it.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
Re: 4 cyl to V6
I've heard its cheaper and easyer to sell the rs and buy a gs then swap rather then swap a v6 to the 4cyl. good luck though
Hmm. what to do now..
....maybe a VTEC for lunch.
