I can't find the EGR valve on my 92 rs help!
MX-Dan
Post by MX-Dan »
I can't find the EGR valve on my 92 rs. It failed the Nox on emissions so I need to check that.
WrenchMaster76
Re: I can't find the EGR valve on my 92 rs help!
Post by WrenchMaster76 »
The EGR valve is going to be located near your intake manifold, probably in the middle of that mess of vacuum lines. It's going to have 3 vacuum lines going to it, and is basically going to look like your typical vacuum-actuated diaphragm valve. If you look at the vacuum hose routing sticker on the underside of your hood, it'll show you roughly where it is. I do know that it'll be sitting in a little C-shaped brass mount that the EGR valve will slide in and out of. Hope this helps!
Shady469
Post by Shady469 »
if your looking at your car head on its on the left side of the Intake Manifold. it's black, plastic and looks kinda sorta like ur FPR. but yeah it should have 3 vac hoses going to it.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
