I have a small leak coming from the manifold..???
MX3ChiCk95
Post by MX3ChiCk95 »
My car is running great except its getting loud when I drive because of the manifold? It has a leak or a hole or something. I'm confused. Is that bad? Will that cost a lot to repair? If anyone knows stuff about that..please respond!
Freq2002
Re: I have a small leak coming from the manifold..???
Post by Freq2002 »
Take it to a local muffler shop & see what they say. Justabout all shops will pop it on a stand & eyball it for free. Small shops will cost less, but big shops will be more likely to have the parts on hand.<BR>Find out exactly whats wrong, then call around & see who'll fix it for less. :D
The contents of this post are the opinions of myself and are NEVER meant to be percieved as the "be all, end all". So cram it!! :p
MX3ChiCk95
I took it to a muffler shop and they said the manifold is something you have to take to an "under the hood garage" *shrugs* I'm scared though. I hope it wont cost much :)
Freq2002
Post by Freq2002 »
Take it to a different shop & tell them you have a funny noise & ask em to look at it first. Even if it is actualy the manifold, they may repair it, just depends on the shop. Could be as simple as a weld to fix, dont give up. :D
