UPDATE
UPDATE
For all of you who read the topic called "my car is leaking" this is what happened. I took the car to the shop, it stayed there over night. He said there was an axle boot that was torn. He said I never caused it. He said that for me to cause it I would actually have to go under the car and cut it with a knife. Anyways my baby is all fixed so im happy.
Re: UPDATE
Thats good that it was fixed, you should try to find out how it got torn though.
Re: UPDATE
He told me that he fixes theses things on the regular. He said its a common thing that happens.
- mitmaks
Re: UPDATE
i am not very mechanical, but what happens if you drive with your boot torn for a while and dont fix it?
Re: UPDATE
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mitmaks:<BR><STRONG>i am not very mechanical, but what happens if you drive with your boot torn for a while and dont fix it?</STRONG><HR></BLOCKQUOTE><P>It'll make a crapload of noise for a while. Eventually, and that means a LONG time down the road, it'll sieze and your wheel will no longer turn....that is BAD.
-93 MR2
#129 E-stock
#129 E-stock
Re: UPDATE
I have noticed that normally the boot will get debris in it then it will wear out the CV joint. It will start making a clicking noise when you turn. It will take a while for it to get really bad. Then break.
