important Plug wire ques
Guest
Hello everybody<P>I went to change my spark plugs today and i saw cracks aroung the place where the wire part joins the thicker part which go into the plugs..these cracks are only on plug wires 1 &3....what should i do..the wires have 270,000km??<P>thanks in advance
OsoSlo z28
Re: important Plug wire ques
if you've had them that long, go ahead and replace them. they aren't that expensive.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
disturbed321
depends if you want just a general replacement or some performance ones
I Eat Dodges & s--- Fords
white94mx3
If you want some good but cheap plug wires, I would go with Bosch. They are really decent plug wires, and if I were you, I'd change all 4 of them rather than just the 2 that are cracked, and if you're plug wires are bad, you better check your distributer cap as well, cause it could need replaceing too.
1994 Mazda MX-3 RS (Project RS-T)
