Anyone else have this problem??? Please help
Stevech_2001
When I am racing someone or shifting really quickly when I throw it in sencond it kinda grinds and is really notchy. I heard another guy say something about a stainless steel braided hydrolic line helping but I was just wondering if anyone else has this problem and if you can help me out at all. Thanks.
Steve
hemi1
Re: Anyone else have this problem??? Please help
I have the same problem. My car is a 92 so it's kinda expected, but still when you rev it up when moving in first, then go to shift to second it's sometimes hard to get into gear unless you really shift it hard and fast. As to the cure have no idea.
Stevech_2001
Guest
could be your synchros or pilot bearing, or maybe some other thing, get a mechanic to check it out
Stevech_2001
It may be your clutch Slave Valve starting to leak. They dont cost that much but they are a pain to bleed all the air out of the line unless you have a mityvac bleeder pump.
Stevech_2001
Has anyone else actually experienced this problem other than me????
Steve
- neverenuff
It could be heat, I don't have a stick my Mx is auto but I use to have a supra with the same prob I bought Slick50 manual trans treatment and stuck it in,prob sovled.So I would say try that first It Is cheap and may save you some money.Let me know If you try It and If It worked.<P>l8ta
