need help with my engine
i have recently encountered a problem with my 94 mx3,when ever i start it and let it idle, the idle rate goes up and down some. It gets very close to stalling out and i dont know what i can do to fix this,..any ideas??
I own a 94 mx-3 with alot of mileage on it,...hasnt let me down yet and i want everyone to know that a mx-3 will kick any CRXs a--
Re: need help with my engine
I've heard some ppl say that a torn intake duct(if thats whats its called)I'd start by buying yourself a can of intake cleaner and while the car idles spray around the throttlebody gaskets,hoses and rubber duct.
I have that problem too. check all your vacum lines and your fuel filter I also had this problem with a 626 I had a while back I fixed it by replacing the fuel filter and pump and having the injectors cleaned, check out all that stuff there are alot of things that can make your idle do that. your idle should be set at 700 rpms..
750RPMS to be exact if std.
- jaydog5678
Egr valve will cause it to idle low, almost to the point of stalling. I had to replace it at 160,000 miles. I would do a tune up first and then check for vacuum leaks. If thats not it, test the egr with a vacuum pump. It's easy.
What engine do u have cause my 92 doesnt have a egr?
- jaydog5678
I have a 1.6 dohc, and yes you have an egr valve on yours. It's on the right hand side of you're intake manifold, below the throttle body.
