does any body know.....
I just replaced my clutch and i need to know how many pounds do i have to put on the wheel hub when putting it back on. need the help asap!!!!!!!!!
Re: does any body know.....
Hey there I checked my manual on that topic you are looking at 20 lbs per bolt.<P>Got the information from a mazda manual my<BR>body gave me he works for a mazda dearlership any other questions letme know.
tighten the wheel hub lock nut to 174-235 ft-lbs.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
I put it at 180lbs thanks a lot for the help. adjustable cams are next. any advice on those?
- jaydog5678
what else do you have done to your car?
for the camshaft sprocket bolt, you want between 37-44 ft-lbs.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
i have the prm intake, stage 1 clutchmasters perf clutch, thats it i just started workin on the engine. outside i have a corksport kit with mr2 side vents. how else can i get pics up if i dont have a scanner or digi cam?
ummm do guys have this grinding noise when u put it in reverse? I know i have to adjust the clutch cable but i dont know how to excatly. any ideas?
