More problem w/ it almost stalling
Posted: March 10th, 2002, 1:16 am
by Shady469
my car has started doin this thing where if im coastin to a stop (clutch in) or stopped for that matter, i'll hear a click noise (sounds like something electronic turning on or off) and the idle will go to like 0 rpm, then it'll click again and come back up.<BR>its done it like 3 times in the past week and its not the shimmy shakey thing either cuz i fixed that when i got an RX-7 MAF.<BR>thanx in advance for any replies.
Re: More problem w/ it almost stalling
Posted: March 13th, 2002, 1:47 pm
by djdaran
Hmmm, I have no idea about electronics, but I can tell you that my rpm will slide down really low after stopping from REVERSE. <P>Your clicking noise may point to your air meter-thing (right above the air filter box). Cuz when I was fooling around with mine, I cut open the top rubber seal of that meter, and there are parts revealed that do make a clicking noise. When I contacted the sensitive metals inside, it would vary the idle. Something wrong here would make your idle go wrong. but I'm no expert on this.
Posted: March 13th, 2002, 1:54 pm
by 94MX3
What does your car idle at when in nuetral???
