More problem w/ it almost stalling
- Shady469
my car has started doin this thing where if im coastin to a stop (clutch in) or stopped for that matter, i'll hear a click noise (sounds like something electronic turning on or off) and the idle will go to like 0 rpm, then it'll click again and come back up.<BR>its done it like 3 times in the past week and its not the shimmy shakey thing either cuz i fixed that when i got an RX-7 MAF.<BR>thanx in advance for any replies.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Re: More problem w/ it almost stalling
Hmmm, I have no idea about electronics, but I can tell you that my rpm will slide down really low after stopping from REVERSE. <P>Your clicking noise may point to your air meter-thing (right above the air filter box). Cuz when I was fooling around with mine, I cut open the top rubber seal of that meter, and there are parts revealed that do make a clicking noise. When I contacted the sensitive metals inside, it would vary the idle. Something wrong here would make your idle go wrong. but I'm no expert on this.
What does your car idle at when in nuetral???
No Cop No Stop I Dont Care<P>Daniel Jones<BR>94' Mx-3 RS<BR>Blaze Red<BR>1.6L DOHC
