shifter loose??
Stevech_2001
shifter loose??
Post by Stevech_2001 »
I have a 94 5 spd 1.6 dohc and I was wondering about the shifter mine seems to be very loose and can move around a lot even when it's in gear is this normal or should I have it checked out.
Steve
David Witherow
Re: shifter loose??
Post by David Witherow »
thats usually due to your shifter bushings go to mazda and get a couple there not that much money.....they not that hard to change either just jack up your car and unbolt the shifter linkage pull out the bolt and put the new bushings in place and put it back together.....
ProtegeSTS
Re: shifter loose??
Post by ProtegeSTS »
get the bronzeoil ones if you can.
-93 MR2
#129 E-stock
charcutron
Re: shifter loose??
Post by charcutron »
they sell the complete kit<BR>you cannot buy only the bushing<BR>you have to buy the linkage but it is not expensive 80$ can. ;) <BR>sorry for my english im triyng
charcutron
Shoalinfist
Re: shifter loose??
Post by Shoalinfist »
Where can I order the bronzeoil from here in America and is that the best ones or is there some better ones I could buy???
