Clutch. Need help.
simon
Clutch. Need help.
Post by simon »
I need a new clutch badly. I was looking on nopi.com and they have a SACHS brand clutch for 97 bucks. Has anyone ever heard of that brand or had one? I need an inexpensive clutch.
powerman_5000
Re: Clutch. Need help.
Post by powerman_5000 »
Go to clutchmaster.com and check out their clutches. Just to let you know clutches are not cheap and getting them installed is not cheap as well, because I just had one put in myself. The clutch+installation came up almost to US$500.
93mxrgs
Post by 93mxrgs »
clutchmaster makes a DAMN good clutch i know since i have one in my car,(stage II) i would recommend them to anyone, dont buy a cheap OEM replacment if ur gonna do it make sure u uprgrade at least 50% of the holdin power above stock, its gona be worth it the more mods u make.
Black-93 mx-3 Gs-R<BR>with goodies :) :)<BR>Hondas suck, and yes i race them...<BR>oops i mean no no i dont
powerman_5000
Stage II; isn't that a bit too much. Why stage II? How much horsepower are you putting out? I figured you would only use a stage II or above if you were putting out lots of horsepower. Now if you were running the stock engine it would be ok to run a oem clutch or the stage I clutch, but if you put in a stage II or above that would be ridiculous.
