performance radiator
Well I am doing the B6T engine swap in my 92 sohc. And I believe if you do something why not go all out. I need a new radiator for my car because my old one is leaking pretty bad and figured why not get a performance one like one of those light weight aluminum ones made by fluidyne. But they only make em for rx-7's and miata's. but they do also make one for the 1.6L miata. could I make that one fit to my car or does anyone know where i might be able to find a aluminum performance radiator for the mx-3?
Live hard, drive fast, back down to no one.
Re: performance radiator
first thing you need to do is take measurements of your current one, after that...call fluidyne and ask for the specs of their sizes. If one is close enough, then you could probably easily weld on some new flanges to get it to fit correctly. No big company is going to build MX3 specific radiators at this point, so i wouldnt even try.
-93 MR2
#129 E-stock
#129 E-stock
