underdrive crank pulley
is it possible to put an underdrive crank pulley on the sohc . this is probably a stupid question but ohh well
Live hard, drive fast, back down to no one.
Re: underdrive crank pulley
I don't see why not...i think corksport sells them, and i saw some at JCWhitney.com too
yeh but on the websites it says dohc not sohc
Yes I have it on my mx, just have to change the belts.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Ramfis Mx3:<BR><STRONG>Yes I have it on my mx, just have to change the belts. </STRONG><HR></BLOCKQUOTE><P>what engine do you have?
Jonathan Michaud
93 Red RS
93 Red RS
which pulley did you buy? <P>did you buy the one for the dohc mx-3 by unorthodox or what?
I'm going to do it to my DOHC once I get a bigger alternator(my lights drown out already with the stereo and driving lights)
'95 Blue Creek Mica RS<BR>Vermont
those really aren't recommended unless it's put on for track use. for daily driver, it's bad on your engine. granted, it frees up parasitic drag and thus gives out more hp, but the pulley(s) are rarely completely balanced which in turn, messes up your crank in the long run. just my .02
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- cjthor
Bad for the daily driver? Actually I have had mine on since 60k and I am now at 88k and everything is fine. My AC and power steering works just fine. I havent had any probs at all. I have a dry cell battery and it keeps up with my 500 watt stereo system just fine. No probs here!! <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cre8v mx3:<BR><STRONG>those really aren't recommended unless it's put on for track use. for daily driver, it's bad on your engine. granted, it frees up parasitic drag and thus gives out more hp, but the pulley(s) are rarely completely balanced which in turn, messes up your crank in the long run. just my .02</STRONG><HR></BLOCKQUOTE>
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
The real problem with UD pulleys is the fact that the crank snout on most B6 motors is too short. The new pulleys lack the harmonic balancer that the stock ones have. This causes vibration that eventually wears at the keyway until your crank snout shears off. Just ask any 1.6l Miata owner who has tried this. B6T owners should stay away too.<BR>
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
