I NEED HELP WITH MY VENTS!!
ok.. to make a long story short... a friend of mine ripped my dash apart to fix some wiring with my deck.. and he screwed up my vents somehow.... i can only get heat blowing to my face.. and winter is comming and i dont want cold feet.. and i dont want to scrap ice off my front window every day :S thanks!!!!!
Mr. LeMans
Re: I NEED HELP WITH MY VENTS!!
It doesn't change at all, no matter what you do? And, before he ripped it apart, is that where your heat was probably set at coming out?
Look under the dash to the box where everything is controlled from heat/cooling wise(sorry cant remember the name of the box at this moment). Its on the passenger side under the glove box. Havent looked at the one in the mx but see how the rods that control the vents are and check how it is connected. You will see it. If anything is disconnected, hook it up...simple. If not, I dont know really. Someone move this to different forum please, thanks.
