FS: NIB set Hella FF50 Driving Lights
Brand new Hella FF50 Driving Lights (High Beams) with mounting hardware and full wiring harness made by Hella with quality Hella fused relay. New Hella H7 bulbs included. Basically, all you need to hook them up. These are quite unique lights as they use a powerful H7 halogen bulb instead of weak H3 that most other ones use. Visit this site and get more info if you wish. Cliky Please check the light tunnel for the beam pattern. You will see that these are auxulliary high beam pattern lights and may not be used as low beams. Btw, on Hella site it's the oval ones.
I was going to use these in my headlight retrofit project, but I decided to use other ones. These have not been installed ever. Just used for measurement and placement. Bought brand new for US$55.00. Will sell for US$30.00 plus shipping. You can easily find out that wiring harness alone is worth about US$25. My loss is your gain. If you want better distance lighting at night, then get these, you will not be disappointed. These are not any cheesy useless lights, these scream quality and they are. Email or PM.
Re: FS: NIB set Hella FF50 Driving Lights
Pm replied to.
Here is what's included:
<img src="http://mediaservice.photoisland.com/auc ... 008502.jpg" alt=" - " />
Still for sale. Any takers.
PM sent. Just wondering what total would be, shipped to 74465.
If not broke - don't fix, modify. If broke - fix it right, and make it better.
ProjexLaden, PM Replied to.
another PM on the way
These are awsome lights. They are the same ones mounted in my headlights as a extra high beam. I'll have pics of my beam up tomorow, took pics tonight.
Mods:
PM Replied.
Item has been sold.
