headlight haze
littleindianboy
headlight haze
I saw a post a while back about haze on the headlights, someone said something about buying glass assemblies. If you really want to get the haze off your headlights use a medium/fine rubbing compound and a buffer. If you don't have a buffer you can just rub it in by hand using a cotton cloth. hope that helps.
Re: headlight haze
I too had the haze on my 94 RS headlights and took care of it with a rubbing compound...it worked very well!
