Thanks all.
Rear Axle assembly needed
Hi all. I have a 95 MX3 with disk brakes in the front and drums in the back. I am going to put some KVR discs all around but I need some parts from a MX3 that had disc brakes in the back. What I need is the rear axle and brake assembly from a GS or comperable model. Anyone have any ideas on how to get my paws on some? Please respond here or email me at FLYLOW22@aol.com
Thanks all.
Thanks all.
Re: Rear Axle assembly needed
hmmmm. no takers for weeks now....
- Custommx3
- Site Administrator
Probably because its in the wrong Forum.
Moved to for sale/trade..
- papa roached
Rear axles?
