Played at the garage for a few hours.
First splice was the low fluid level thinger on the brake fluid container. That is it for the engine compartment!
Next spice was the dimmer switch, it I were to do this all again, I would have saved a ll the mx-3 switches, then it would have been plug and play. I could have mounted all the MX-3 switches in the options I do not have plates LOL.
Most of the wires are the same color from car to car, so it was pretty easy splice-in some plugs deal.
Next spice was the cigarette lighter and the light bulb. Same color wires.
The Hazard light splice did not go so well. If you wire the four matching colored wires together the hazard lights do work, but the switch does not light up. The switch has an extra orange wire on it. I screwed around for a while , but could not get it to light up. It you add power to the green wire it does light up, but solid, it does not flash on and off like in a normal 323. I need to look at the wiring diagram for this one.
By far the happiest part of the night was the heater. I was scared to death of it. My MX-3 had the Knight Rider Darth vader digital climate control deal in it. There are like 5 plugs that go into it. One of the plugs fit into the standard 323 blower motor switch, but the plug appeared to be wired very differently. I plugged it in and prayed for no fires. All my fears were for nothing. On the blower motor side I plugged one of the five plugs into the blower motor resistor and then I cut a big blue power wire off a plug I marked blower motor, and spliced it on to the 323 blower motor feed wire. To my delight the heater actually works and no dash fire! Aw-right!
I took the mounting brackets off the MX-3 cluster, I plugged in, and placed it in the dash. Like Dan had mentioned, it fits pretty good in there. About half an inch of open space on both sides of it, I may make little filler panels to make it look more factory.
The yellow light means I am low on gas LOL
![Image](http://i155.photobucket.com/albums/s309/IMACHU2/MX%20326%20GS/017-6.jpg)
