Thefez's 92 MX3 GS (Buying a RX-8!)
- mx3_ryder
Re: Thefez's 92 MX3 GS *going crazy*
Like the euro vent man!!
What size are those tires?
Thefez
205/40r17
thanks!
thanks!
- AaronTietje
That's purdy. Keep up the good work.
- kulluminati777
that does look rather nice.
Thefez
kulluminati777 wrote:that does look rather nice.
why thank you gentalmenAaronTietje wrote:That's purdy. Keep up the good work.
Thefez
Re: Thefez's 92 MX3 GS *Head case*
SO after my KL swap like anyone that has done it the car felt like a rocket and was amazing well now its time for more power it got old after the first 2 weeks lol..
I picked up a KLG4 IM and a set of COLT 210 cams from AaronTietje, and the IM from Elli, thanks guys!!!
I wana squeez has much power outta this KL as i can without opening the bottem end for a KLG4 crank and ZE pistons.
The next phase is to put the cams in and the IM, get a KL ECU custom tuned to support the MODs and get the car dyno'ed to see what she puts down.
Befor the cam and IM go in the head heres the decision i have to make should I buy spare Milli or ZE heads and P&P them and add Interprep valve springs and send the G4 out for an extrude hone... or just slap everything in there and hope the Milli vavle springs hold the new cams without dropping a valve.
opinions? lets here them!
Thefez
So spent some time with the car today and last night.. time to do stuff on her has been limited due to wanting to finish my 66 mustang project...
So i finially fixed my dropped shifter with reappling the rubber so to speak, I aligned the rod with the bass and after sanding and making small grooves i applyed "window weld" and let it bond, so far it feels really stiff and firm so well see how long it holds up
Also while i was at it i filled and repainted my rear trans mount going to get that on this week sometime along with painting the mazdaspeed front bumper
I plan om filling the front trans mount with the "window weld" as well. pics up later in the week once the bumpers painted
Thefez
Re: Thefez's 92 MX3 GS *7/7/13*
Well ive been rather busy with projects between my 66 mustang and my MX3, but i've been getting a TON! done and i feel making alot of progess..
ive started repainting the car the mazdaspeed front bumper has been renforced and primed and painted, as well as my euro side have been put into primer as well, since the car is my DD I have to paint the car in stages, not my ideal way of painting the car but sometimes you have to do what you have to do.
I also started to P&P my G4 IM i still have to do 4 more ports and work on where the TB is put on. Once the P&P work is completed, as well has a shave and paint job and my COLT's come back from the machine shop, everything is gunna be installed on the motor.
I also been contimplating to change my muffler from the borla xps pro to something like a Flowmaster super 10 or 40, something with a deeper tone, any sugestions?
I finally got my bushing nuts made for my cuzco camber plates by rocketman. I also got around to refinishing them since somewhere along the line someone decided it was a good idea to paint them black over the anodizing...
(picture in mid process of being made by rocketman, ill have final product pics up later)
also last a small minor thing finally got alround to installing my rear filled mount.
I have also made a quite large decision on deciding that im gunna remove the sunroof in my car due to its profuse leaking and I can't take it anymore!.... i blew out all four drains and it still continues to leak.. so rather then spend the $200+ that mazda would like for the new gasket.. im gunna weld or "glue" over a non sunroof roof skin and delete the sunroof, plus it will add a bunch of head roof for my taller passengers..
- Surgeonasst222
I would pay $200 to keep a sun roof as I wish I had one and maybe you need shorter friends
Mazda3 2012 - my NEW DD
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold
- AaronTietje
WOOT sunroof delete.
Thefez
ya right, I really do love sunroofs but without look so much cleaner and I also like when there glass not solid like how they are.Surgeonasst222 wrote:I would pay $200 to keep a sun roof as I wish I had one and maybe you need shorter friends
thank you, thats a big compliment.Caleb T wrote:Nice looking car man, Clean work!
yes and i might have located a car without a sunroof i might pick up in the next week or 2 so gunna pull all the parts I can save and store junk the car and trans save a good K8 I was told its a v6, and the suspension parts to clean and repaint or powdercoat them to swap on my car. Want to do as much rust proofing has I can befor winter since this car is my dd and will soon have a fresh paint job. the rest will be cut up and scrapped to recoup some money back from the car.AaronTietje wrote:WOOT sunroof delete.![]()
- AaronTietje
Thats a good way to do it. I have honestly built my mx3 by buying parting and scrapping the remainders.
A non moonroof v6 is a bit of a hard find tho.
If it ends up being a 4cyl 5spd, I'll buy the harness off you.
Thefez
its deffinitly a v6 and its auto:/AaronTietje wrote:Thats a good way to do it. I have honestly built my mx3 by buying parting and scrapping the remainders.
A non moonroof v6 is a bit of a hard find tho.If it ends up being a 4cyl 5spd, I'll buy the harness off you.
