Offical Spyder MX3 Halo Projector headlight (Black / Chrome)
- onlytrueromeo
Re: Offical Spyder MX3 Halo Projector headlight (Black / Chrome)
Man when did you sell the car? How did I miss that? Maybe I'm just not remembering?
Boo when someone lets one go
I sold it in May 2008.onlytrueromeo wrote:Man when did you sell the car? How did I miss that? Maybe I'm just not remembering?
Got a new 2001 Mx-5 (Miata) Sport package instead
(had a 99 (Ford) Mercury Cougar from oct 07 to june 08 too, but luckily I got back to a decent car).
-n
- Shades
Just got around to installing my headlights tonight... did anyone have a problem with the hood closing cause the headlight sits too high?
I didn't have a chance to look for an adjustment bolt cause it got dark, can anyone shed some light?
"Do it ONCE, do it RIGHT!"
- onlytrueromeo
^Are your bottom bolts in? (The ones you have to screw through the turn signals) I was debating not hooking those bolts up because they're such a PITA to get to, but they lowered my lights down to where I needed them.
And there's a peg in the bottom end of the housing that needs to fit through a hole in the frame, if that's not in along with the bottom bolt the lights would sit high.
- Shades
Yup, all three bolts are in... I'll have a look today in the light, just wondering if anyone else had this problem and had already fixed it.
Has anyone talked to Ray lately? I've been trying to reach him; I still haven't received my HID kit.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
- Mazdaspeed96743
I love my headlights....., I love my headlights......, I loooooooove my headlights
I messaged spyder about the fire hazard with his lights and NO response. Wire fell out while I was installing mine and that's just not acceptable. He hasn't responded to my Email so I recommend no one buy from him (carpart4u). I'll fix the wiring on my lights and hopefully no ones car burns as a result of his in action. Be sure to check the security of the wiring before you install. Just so you understand my back ground, I've worked on aircraft for almost 30 years and I have extensive electrical experience.
He isn't responding to me either. One of my rubber seals fell off at some point, as well as one of the clips that keep the front on. Now I've got a slight moisture problem in one of the lights.
I'm even willing to pay for replacement parts (though surely this should fall under warranty). I just want to get it fixed. No response though..
- Gord
http://carpart4u.com/help.php?section=c ... ode=update" onclick="window.open(this.href);return false;
Have at you!
Have at you!
mine work fine(ebay). only problem is, the dumb h1 hids i bought wont fit in......i wanna be bright with my projectors not pi$s color yellow bulbs....
___________________
Black '92 GS [Project De-t Started!] [The spoiled one]
Green '95 1.6 [Daily][The jealous one...SOLD]
White '07 Mazda 3 GT [The pretty one]
[What can you say, I have a fetish for 3's]
mikeetown wrote: Do what you want to do dude cause in the end, your mx-3 is all about you.
- Mazdaspeed96743
Which wire was that Daninski?Daninski wrote:I messaged spyder about the fire hazard with his lights and NO response. Wire fell out while I was installing mine and that's just not acceptable. He hasn't responded to my Email so I recommend no one buy from him (carpart4u). I'll fix the wiring on my lights and hopefully no ones car burns as a result of his in action. Be sure to check the security of the wiring before you install. Just so you understand my back ground, I've worked on aircraft for almost 30 years and I have extensive electrical experience.
LED's, white wires
You didn't actually think he was going to stick around did you?? He got your money and left! It's how it works!
