Page 46 of 53
Re: Offical Spyder MX3 Halo Projector headlight (Black / Chrome)
Posted: March 8th, 2009, 1:11 am
by SuperK
My projectors are kinda wobbly and not secure.... when the hood is up, I can take the light and wobble it back and forth... Anyone else's lights like this?
Posted: March 8th, 2009, 1:43 am
by tehbrookzorz
So will there be another gb down the road? I'll be broke for months yet, but I'm curious.
Posted: March 8th, 2009, 1:53 am
by onlytrueromeo
My projectors are the same, Kris. I thought I installed them wrong when they did that. It looks like its the rubber thats flexing, rather than the plastic.
Posted: March 8th, 2009, 12:47 pm
by sishi
Hopefully Ray is still on forum...from time to time and check PM's...
Posted: March 9th, 2009, 9:49 am
by colinf004
Ray, I still haven't received my order I placed 2 weeks ago.....
I haven't even received an tracking #'s ?????? any reason why I haven't seen any numbers yet?
Posted: March 9th, 2009, 1:45 pm
by ray carpart4u
all pms replied, don't worry, i am still with you guys. But as far as the installation stuff, Jesse might know more than me, i still never seen one in person in CA yet.
-Ray
Posted: March 9th, 2009, 4:07 pm
by nightfire
Just got my headlights. Outstanding build quality and packing job! Thanks Ray and everyone else who helped the group buy succeed!
Posted: March 9th, 2009, 4:47 pm
by Jutzi420
I'll weigh in on these puppys now that I've used 'em for a few days. I have a few minor gripes.
I had a problem with the leds as well, I tested 'em before I mounted the lights and everything was cool, then after I installed them 3 went out. So I yanked all of 'em and made sure the wires were lined up right, now they're perfect.
I also noticed that my driver side light seems a little loose, not terrible bad though, I haven't looked to close yet to see why only the one is wiggly. I'll check it when I aim them properly on friday, right now they've only got a 25 foot "that should be pretty close" adjustment.
Other than that they're built crazy solid. It took me twice as long to get the lenses off of these bastards than my factory lights, I think it took me over an hour to get 'em both off with a good heat gun. I wouldn't be too worried about moisture unless you see a total gap in the sealer.
Posted: March 9th, 2009, 10:05 pm
by nightfire
I just noticed something ...
I ordered the HID kit (6k), and don't have any ballasts. Is this normal? Are the ballasts internal to the lights, or did I receive the regular halogen lights?
They also look awfully yellow for 6k.
Posted: March 9th, 2009, 10:12 pm
by Jutzi420
When I got mine the reg H1 bulbs were in the lights, and the HID kit was packed in a white foam, umm... packing... in one of the light boxes. The ballasts are about 4x3x1 plus a bunch of wire.
Posted: March 9th, 2009, 10:39 pm
by Flyer
I am still trying to figure out how to get the lightbulbs out of the high and low beam compartments repsectively...
Posted: March 10th, 2009, 12:19 am
by fowljesse
I didn't screw with the high beams, but there's a metal wire curl that you have to push in, and toward the light, to get it under the retainer. I could take a picture of it, if you have your lights installed already.
For the record, I haven't had a single issue with the lights.
For the wobbliness, could you put up pictures or vids of where the issue is?
Posted: March 10th, 2009, 2:47 am
by nightfire
Jutzi420 wrote:When I got mine the reg H1 bulbs were in the lights, and the HID kit was packed in a white foam, umm... packing... in one of the light boxes. The ballasts are about 4x3x1 plus a bunch of wire.
Yeah mine was definitely missing. I PM'd ray.
I'm actually surprised how bright the non-hibeam halogen lights are. But not blue.
Posted: March 10th, 2009, 6:12 am
by albarsv
Yesterday I receive the headlights
They were packed very well and nothing is missing. Headlights seem better than on pictures
Just some questions:
- the low beam position lights are the outer one? So I have to install the HID kit there, correct?
- the black led's wires is the ground or the +12V wire?
Any hint for mounting and/or connection?
Thanks
Posted: March 10th, 2009, 11:18 am
by Jutzi420
Black is the ground.
