Okay, I went to the scrap yard yesterday and picked up a set of ZX2 struts. I also got... oh right, the lifters for that other thread I made
Ryan's Guide to Healthy Lifters
Anyway, the ZX2 struts.
I only did the front ones today, because you need to change the caps for the rears, and I am lazy, so I will do it later.
![Image](http://i278.photobucket.com/albums/kk82/RyanThomsonRyan/Gril%20Bay%20and%20Small%20Mods/IMGP0222.jpg)
Stock on the bottom, with the recall strut brace deal on.
The recall brace does not fit on the ZX2 struts. The tab is slightly too long, and the diameter on the ZX2's is slightly larger. It could be made to fit with some fab work, like cutting the tab to fit and bending the radii larger.
This mod cost me:
$40 CAD (+40 for rears)
2 hours
I used:
14mm deep socket for strut tower bolts
17mm for the bolts holding the strut to the hub
Breakerbar
Pliers to pull the clip out that holds the brake line to the strut
Hammer to loosen things up
Tire iron & jack
A screwdriver to assist lining up the strut holes to the hub holes
Another ratchet with an short 17mm to hold the bolt opposite of the strut nuts.
A buddy
Before
![Image](http://i278.photobucket.com/albums/kk82/RyanThomsonRyan/Gril%20Bay%20and%20Small%20Mods/IMGP0220.jpg)
After drivers side is on
![Image](http://i278.photobucket.com/albums/kk82/RyanThomsonRyan/Gril%20Bay%20and%20Small%20Mods/IMGP0221.jpg)
After both are on
As you can see... I'm sitting higher. Everyone says "ZX2 springs are about a 1" drop" I think thats for the v6 guys. 4 cyls, Its a bit of a raise.
I drove around, slammed some brakes, pushed around some corners, swerved around on a road, and they DO feel better to me.
So I'm keeping them. To address the raise, I think I'll just plop a bigger motor in and maybe some
heavy cast 2.5" turbo pipes....
Also, I'm putting my BP swap off untill spring. Unless an amazing opporunity presents itself.
Black GS - Summer DD/Race car -
Fancy KLZE
