easy no bake way to remove headlight grime.
- kudkudniyog
- kudkudniyog
I cleaned mine the 3 minute way... not the best way, but it costed me 3 dollars... I did a shoddy job and was in a hurry, but I'm going to head back out there and give it a deeper clean.
picture time
before:
after:
What did I use? DOT3 Brake fluid. The cheapest I can find. wipe on, wipe off. Unfortunately, I didn't get the corners too well (was scared of the fluid EATING my paint) and I plan to polish them when I re-clean them.
but brake fluid worked pretty well for me, it's a very cheap alternative, I suppose
picture time
before:
after:
yeah that looks good, need to try it on mine
95 RS Blaze Red, RTX 17's Gunmetal with Polished Lip, Falken Tires, GS Lip, Carbon Fibre Altezza Tailights, Black and Red Interior (front/rear seats, door panels, and rear panels. GS Spoiler, Hood with scoop, Black Mirrors, Pioneer Deh-p6800 Deck, Infinity 6010cs components, infintity 4x6 Rears, Red Shift Boot , 12 Blue Interior Lights throughout car and 4 leds in vents wired to 2 switches total
http://www.mx-3.com/phpbb2/viewtopic.php?t=54606
http://www.cardomain.com/ride/2394622
- eyezpinned
great method
bump for the great method for bringing headlights back to life. used the exact method (mother's) described with similar results.
Remember, polishing only gets you so far. I just cleaned my headlights this evening, and I inspected them closely. there's a thin layer where the plastic is physically degrading into a crusty mess... where I failed to properly clean it.
I'm going to fetch me some polish for my headlights and polish them off, but I'd very much recommend removing a actual physical portion of the headlight beforehand... and brake fluid does a wonderful job at EATING stuff
leaves a horrible yellow mess on your wiping cloth, though...
that's why removing your headlights to be buffed is so recommended, it physically removes that small layer of old grime.
Sure, your headlights will still turn grimy again, but it shouldn't happen for a few years.
I hear the reason for fogging is because of a bad batch of plastic that was brewed around the early-mid 90's... I'm sure some aftermarket plastic lenses would look wonderful and not grime over...
I could be wrong, but this is the conclusion I've come to myself. Of course... we all know all my opinions are professional, right? right??
- mitmaks
gs27 works great too
