Sleeper6's Gold 92GS Updated paint pics!
AaronTietje
Re: Sleeper6's Gold 92GS
Post by AaronTietje »
Your completing your set aren't you???
If so, im def. green with envy. :mrgreen: :mrgreen: :mrgreen:
Your going to have to stop by so I can check out whatever it is. :lol:
Sleeper6
Post by Sleeper6 »
nope think bigger, with much more jealousy :mrgreen:
AaronTietje
DUDE what are you getting.........................Ok will it be able to be put on in a few mins. or will this take several hrs to put on??? :D
Sleeper6
Post by Sleeper6 »
http://www.collegehumor.com/pictures/ga ... 10#1942750" onclick="window.open(this.href);return false;
Pic 22 is way too funny
Anyhow the plan is a shiny new hood if the trade works out, Ill keep you posted and hopefully find the charger for the camera.. those things need beepers
Sleeper6
Post by Sleeper6 »
The new projectors all installed :mrgreen: :mrgreen:
What a mess... So I tapped the vertical leds into my turn signals for a nice touch. Im still a bit sad about the halos (theyre not too bright at all :( ) Also I traced down teh relays and figured them out finally. The red leads will keep the low beams on when You hit the highs if you wire them in, which I plan on doing once I finish dialing in the lowbeams and eliminating/tucking some harness.
So hopefully come monday Ill have some new pics and a cleaner install not to mention a carbon hood if it works out for the 5th time? Oh and hopefully a splash guard/center tray from trollis on its way as well!
AaronTietje
Good to see some pics. Those lights do come with a mess of wires. Have fun trying to make it look neat in your bay :lol:
Hope you get that hood. It would set the car off very well. :mrgreen:
Sleeper6
Post by Sleeper6 »
AaronTietje wrote:Good to see some pics. Those lights do come with a mess of wires. Have fun trying to make it look neat in your bay :lol:
Yea a mess is right, so far Ive managed to get some conduit stretched under the air dam over the radiator to make it clean, but i still want to shorten those harnesess up. Atleast thats the plan for monday if hte weather holds out. ALso im looking into this funny issue where the LH low beam drops intensity after the highbeams are clicked now that I joined up the relays to the battery. Hopefully its just a loose ground in one of the harnesses.
AaronTietje
Yea a mess is right, so far Ive managed to get some conduit stretched under the air dam over the radiator to make it clean, but i still want to shorten those harnesess up. Atleast thats the plan for monday if hte weather holds out. ALso im looking into this funny issue where the LH low beam drops intensity after the highbeams are clicked now that I joined up the relays to the battery. Hopefully its just a loose ground in one of the harnesses.[/quote
Hmmm.... I never got that far as I only "plugged" them in. Your welcome to come over if you want some help on it. We could pull it in the garage, that way you can work on in regardless of the weather. :shrug:
tripleMX-3chicMS
Post by tripleMX-3chicMS »
Lookin good man... Glad you're gettin it all figured out. Thanks again for sending me your head light.
It looks so much better then my other one.
93*4 GS SE's for parts ONLY*
Sleeper6
Post by Sleeper6 »
Road trip to amherst, NY tonight, wish me luck :mrgreen:
Sleeper6
Post by Sleeper6 »
So I didnt get around to cleaning up my wiring as planned however I did do a little modifiying thanks to the father -in-law drilling service :mrgreen:
We had to tap in to get the hood pins on as it didnt sit safely, Im still planing on weatherstriping the front to seal the air out and clean it up around the headlights. But other than that what'cha think?
Dark_Rider2k3
Post by Dark_Rider2k3 »
man there are a lot of wires for the projectors >_<
but I thought it was pretty much plug-and-play in terms of the actual headilghts? Like I thought the only wiring needing done was for the halos and led's? Which, wouldn't that make only 4 additional wires?
Sleeper6
Post by Sleeper6 »
Dark_Rider2k3 wrote:man there are a lot of wires for the projectors >_<
The headlamps are plug and play, unless you hook up that red lead with the fuse&relay attached to the battery. Then your lowbeams will stay on when you hit the highs. And each halo had its own harness as well as the triple leds. So I pretty much need to pull em back out and shorten the harnesses up and put some conduit over it all so it looks better.
Dark_Rider2k3
ok I gotcha! Simple enough!
Sleeper6
Post by Sleeper6 »
heh im surprised no-ones pointed out the funky color on the rh fender :lol:
