[FS] SRD Reproduction Parts - Crossmember, Tie Bar & E-Brake
- tehbrookzorz
Re: [GI] Aluminum Crossmember & Rear Tie Bar - SRD Reproduction
What's the word?
I want to plant a seed of thought... Aluminum crossmember modified to fit turbo mx-3s.
Cody
- solo_ryder
You dont need to modify that crossmember for a turbokit do you.. I thought it was the engine crossmember that ran North to South not the SRD one..
- marcdh
Correct, the one the two mounts sit on. Though maybe tehbrookzorz meant that one It would be nice, though there'd be a very small market for it. Then again it's products like that make me think, awk well no excuse now, may as well get turbo togethersolo_ryder wrote:You dont need to modify that crossmember for a turbokit do you.. I thought it was the engine crossmember that ran North to South not the SRD one..
View Worklog
View Worklog
- fowljesse
Wazzzzuuup?
I want these.
I want these.
- tehbrookzorz
- mitmaks
how's the progress on the handle?
Sorry guys, I've been working in Edmonton going on 4 weeks. Although I'm going home this Friday, I'm only home for the weekend and back for another 3 weeks. So being 3500kms away and 2 hours behind I haven't been, or really been thinking about following up on them.
I did message him last night and he messaged me that he'll have the second one done for when I come home...but I don't see that he'd know that I was coming home this weekend. I don't want to pesterize him too much so I don't discourage him from this project, but it's good to remind him once in a while, just in case.
Sorry mitmaks, I haven't heard back from Ian yet. He said he's be pulling the car apart this month, and that was on the 7th. I'll sent him a message to see what's up. I've already called dibs on it, so I just need to get my hands on it and give it to my friend.
- tehbrookzorz
Odds of the other crossmember modified to accept turbo pipes?
Cody
Honestly, probably not. Not unless I have a modified crossmember to use as an example cause I need to how HOW to modify it. Even then, as far as I've seen, there's different ways to do a turbo kit and what's needed to modify to make it work. I'd be affraid that I would modifty it in one way, but for some people it may not work, even worse is if it should work. That's something that I'd like to try, but even if it would be done correctly, for those who buy it and it doesn't work, I'm sure they wouldn't be happy to of spent the money on a large peperweight, and no way am I eating the cost by refunding the money and taking back something that's useless that has no guarantee of working.
The shitty part is that I don't have anyone to give it a try. Oscar has a kit, but his doesn't require a modified crossmember with his new kit...but maybe he did on his old one and still had it...I'll have to ask him. I believe I've seen pictures of modified crossmembers in the past...I'd hope that one being made out of aluminum with that modification would still have strenght to do the job...but that should be part of the way it's designed, and probably require more material and more complex machining.
For the regular SRD reproduction, I'm taking the cost on that since in the end, I could use it myself, or sell it or even my SRD original. If you guys want one that'll fit the turbo, you'll have to help me out with what needs to be done and divide the cost for the prototype and entrust someone to test it.
- fowljesse
AFAIK, the mod would be similar for different apps, so, instead of routing out that part of it, you could leave it solid, so it would have enough strength for them to cut it as needed. Just get a general perimeter of where they will need to cut it, and leave that part solid.
Ok, I've got a question. When I search for, and for what I remember in terms of modifying the crossmember, this is what I think of and get searching for it:
And this is this crossmember that the SRD replaces:
Are both pieces needed to be modified or is there a mistake in terms of what part need to be modified for a turbo?
Well, so you guys silenced from confusion? Lol
My buddy said work's been busy for the last few weeks so be had to put those parts to the side, but today he was in the mood to work on them today, and he sent me an update on the rear tie bar. Apparently he didn't line it up right for the holes, but a simple mistake that shouldn't happen on the next one, lol
i drilled the holes at like .471 i think and then i did the slot with an endmill. and the endmills run really true. so i ran that same endmill down the holes that i drilled to get .500 exactly but stupid me didnt make sure i was in the middle. so i dropped the endmill down like 1/32" off
- RS_OBD'oh_2
that is what I've been waiting for. I've still yet to have one on my RS.
- fowljesse
Grrreat! I would like to have both.
I was wrong about the turbo mod. I guess I read something different. Maybe it was just how 1 person did it.
- mazdax3speed
put me down for a tie bar, i have torn everypart of my RS apart, and not only is there nothing like the GS crossmember underneath there, i donteven understand where the SRD crossmember goes exactly, left to right? infront of the oil pan?
Orange 95' BPT GT28r, MSII on the way
