5' of cheater bar + a hell of a lot of torque applied by my own legs... Hah, bastard broke loose FINALLY.
The other side naturally popped off with barely any effort -.-
At last I can take the MX-3 spindles off and verify 100% that the suspension geometry will be identical with the new setup, as well as taking exact measurements to cut down the Probe spindle where it mounts to the strut.
Remaining for the fronts:
- Pick a set of rotors
- Have the new bearings pressed in
- Grind the spindle>strut mounting surface down
- Bolt it all up
The seller who has the FD wheels I'm after is hard to pin down for a time and date... With my own schedule being hectic as living hell, it could take a while.
I seriously miss driving this car... but it WILL be worth it when I have her back on the road!!
The Mazda3 shift knob fit perfectly, as expected, but it does sit about 15mm higher than my drilled stock knob did. ;( I also need to get one of the MazdaSpeed shift boot mounts, so the boot will actually attach to the knob. The angle of the grip on the knob isn't as comfortable in my hand, but the added weight does slightly reduce the force required to shift(coupled with the additional leverage of a taller knob).
