The photos that were emailed to me(MoonEggs has the full screenshots to prove):
The driver's side headlight was broken CLEAN IN HALF, and "repaired" with a cheap silicone sealant, which had to be completely removed prior to the actual repair that
I completed. The lense and the mounting tabs were the only undamaged components of the driver's side light. I filled in the silver dollar sized hole with a 2 stage marine epoxy, and used a 3M product(Plastic Metal, IIRC) to reconstruct the headlight.
As for my painting of the lights,
I only ever painted the undamaged PASSENGER headlight.
To this day, I have yet to find a single driver's side H4 headlight to replace your "clean" one. No amount of work on my part thus far has been able to seal it solidly enough to prevent fogging in the long term.
Onto the "bumper"... In addition to the highly understated "notches" that were cut into the foglight openings(which I had planned to use for flexible ducting, as we discussed in our correspondence prior to the trade), you failed to take even ONE photo after having removed the GS lip. The mounts were TORN from the bumper, in either haste or carelessness, and the holes were never photographed, nor described. Several of the rusted mounts remained, as I am sure wagZE can attest(as he bought the bumper from me)
SuperK wrote:You are not a member of this community for any other reason than someone took pity on you and refused to ban your a--.
Remember your place. Everyone else knows.
I am fairly certain that the vast majority of the members unfortunate enough to be following this thread can see exactly who is attempting to mislead. Your rage betrays you, Kris.
You can call me names, curse me day and night, and even go so far as to fabricate correspondence. None of that will change the
FACT that you sent me damaged parts, and I called them as I saw them. I love my MX-3s, and I love this forum. Enough to put up with any amount of slander and backbiting, no matter the source. So far as I am concerned, we have no further reason to communicate. My replies are limited 100% to "damage control", as it applies to dishonesty involving my personal character.
