how cold is your AC?
- AaronTietje
Re: how cold is your AC?
My mx3 ac worked better and colder than my 07 Jeep liberty and my now 08 Jetta........So I took it out to free up some HP.
mine is ice cold now that i got a SPAL fan for the condensor, i had to upgrade because i'm turbo'd. If everything is working, you guys should upgrade the fan because this will cause the pressure to lower and move the refrigerant better, causing better cooling, you can also add some more freeon if you get the pressure to drops by better cooling. Good luck guys
