Fuel problem: starving out and surges when accelerating
Re: Fuel problem: starving out and surges when accelerating
lol what codes did you get?
- tripleMX-3chicMS
what codes DIDNT i get.... Throttle pos sen, air intake, cam..... im going to check the wire and plugs to those first before i change them all. They might be loose or the connection might be frail or dirty.... or they might ALL need to be changed. In which case i might as well snap ALL my nails off cuz i have three broken as of this morning. Looks like i dont get to drive the damn thing to Alabama Thursday.
93*4 GS SE's for parts ONLY*
![Image](http://i870.photobucket.com/albums/ab265/DeKaady/mazdaSpeed74x74.jpg)
So you jumped TEN and gnd then got in the car turned the ignition key to ON, the dash indicators came on and the engine trouble light started to flash. Can you tell us specifically what code numbers you got. Your situation can't be as dire as you believe it to be. I'm sure we can figure this out.
