Need a supercharger expert!
fowljesse
Re: Need a supercharger expert!
Post by fowljesse »
.....this computer!
rebel2k4
Post by rebel2k4 »
Call me a hater but you are reinventing the wheel, adding more complexity and headache to an already big project. Boosting these cars is a neverending job as it is.
In addition, 100hp will be around 8-10 psi. An M90 draws roughly 20-45 hp throughout its rpm range (check out the power consumption charts)
Youll be tough pressed to find a motor to spin this. A little 5 hp briggs isn't going to cut it.
98 Ford Ranger 3.0L
fowljesse
Post by fowljesse »
Good to know. Thanks for the info!
I haven't started on this yet, and all the info I can get will help my direction.
There was a guy who reinvented the oil lamp, and he was thought to be crazy :shrug:
If it doesn't work, I will have had a good time trying it. :welder:
Return to “Forced Induction”
