Does SRD control arm bushings squeak??
DJsMX-3
Post by DJsMX-3 »
You need to do a alignment :(
Maybe if someone worked in a machineshop we could perfect theese..
If we put in a metalsleeve like in the original and mazdaspeed bushings, then there would be no over or undertightening, and it would still work as intended because of the near solid bushings..
And squeaks and clonks would be gone due to the fact that all frictionpoints would be like standard OEM
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
jschrauwen
Post by jschrauwen »
Josh wrote:Their is a special Polyurethane grease that your supposed to use when installing any poly bushings, to eliminate all squeaking. you get it with some swaybar kits for other cars. i cant rember the name but if i do ill post it.
Josh, you must have the name of the grease by now??
jschrauwen wrote:
Macen wrote:Mine squeak a lot now. A bit annoying, but I will have to live with it.
Would be nice if we can find a grease that last and prevents the squeaking. Though I'm not that interested in removing them again and then do a new alignment.
Please tell me that I don't need to get another alignment after I put mine in.
DJsMX-3 wrote:You need to do a alignment :(
Damn, this is going to get real expensive since I just got one done 3 months ago. I guess it's better to know now....thanks DJ.
Macen
Post by Macen »
Does the Mazdaspeed bushings also squeak?
I'm getting tired of the squeaking from my SRD ones.
Black '93 GS-RL KL-DE
White '95 RX-7 Type R Bathurst
http://macen.nullnet.com
Post by Josh »
I put mine in about 3 weeks ago. I used white lithium grease. NO SQUEEKS at all (grease goes on the bolt threw the center) (and don’t use graphite grease, that stuff is crap). I have a nice clunk but it’s not from the bushings. I actually pressed mine into the stock sleeve.
When installing them or any bushing for that matter. You need to let the full weight of the car settle on them before you tighten them up. So with the car on the ground I tightened them up. No problems at all, very nice to ride NO wheel hop at all now. Steering is way tighter now as well. But on the other hand my oem bushings were falling apart, so anything was better then the ones that were in it.
Macen
Post by Macen »
Yeah, I heard from a guy that lithium grease or silicone grease will work. I will try it. Hope the squeaking will be gone.
Gro Harlem
Post by Gro Harlem »
my poly bushings that i used to sell here don't squeak.
i used a total assload of the supplied grease that came with em tho, but they've been installed for a little over a year now and i haven't heard any squeaks yet.
DONATE TO MX-3.COM
Postman2K
Post by Postman2K »
Macen wrote:No, I used a normal vice/vise. They went in very nice and easy.
i plan to install my SRD bushings real soon. does removing the Control arm throw off the front wheel alignment? do u suggest installing them first before alignment or does it really matter? thanks
Post by Josh »
definatly install them before the alignment. it will throw it off some.
Macen
Post by Macen »
I put some new grease on the front bolt. Removed the rear bushing from the "bolt" that is on the control arm, and greased it too. Put some liquid grease down below the hole where the front of the control arm is mounted.
And now it dosen't squeak at all. No need to push the bushings out. All I needed was some grease.
NOTHING
Post by NOTHING »
the correct way to install control arm bushings...........after you press the bushings and install the control arm dont tighten the bolt, u have 2 have the car on the ground the way it would b normally then tighten the bolts. in reality this is pretty much impossible 2 do so what i usually do is put the wheels on a couple of cement block or what have u put em under the tires and lower the car onto them control arms will b similar 2 what they would b when on the ground if u dont do it this way normal bushing can get ripped apart i've seen it happen especially on suv's, anyhow this is the way i do it and usually the way u get taught at seminars on suspension, just thought u guys might fixx your squeekin probs with that
