New Real coilovers for our car!
Steeb
Re: New Real coilovers for our car!
Post by Steeb »
coilovers offer higher spring rates and tuned dampers. that alone will drastically improve handling, body roll, and grip. just because you have coilovers does not require you to take advantage of corner weighting to see handling benefits.
corner weighting can be done with a regular spring and strut combo but it is not required either to see handling benefits over a stock setup
ProtegeSTS
Post by ProtegeSTS »
uhh, how do you plan on corner weighting a car that you cannot adjust ride height?
for a MX-3, the BEST solution is still Ground Controls and Koni inserts, IMO.
This crap is just that IMO. The spring rates are unknown, the dampning rates are unknown. They aren't serviceable, they aren't rebuildable, you cannot select spring rates.
These are good if you want something that bolts on and you can forget it and you don't care to "think" about your car's performance.
-93 MR2
#129 E-stock
mazdubber
Post by mazdubber »
Coilovers or not, spring and dampening rates can be tuned to whatever you want.
I don't dispute any benefits. However if corner weighting is not performed, FULL handling benefits would NEVER be reached! In fact handling could be severely compromised.
All this tells me is that you probably don't know what corner weighting is. :shrug:
92 GS
'Stock'... :twisted:
ProtegeSTS
Originally posted by mazdubber:
[QB]
not if you don't get adjustable struts, and there aren't many for the MX-3. And you can't use universal 2.5" springs or the like without the use of a coilover sleeve.
-93 MR2
#129 E-stock
mazdubber
Post by mazdubber »
First of all, I wasn't referring my comments towards the mx-3. It was just a general comment. And as far as springs go, If you have the money, you can get many small, and some larger machining companies to build you a custom rate spring. Same goes with dampeners. My point was that coilovers are not the only way to a very well tuned spring and damper combo.
92 GS
ProtegeSTS
Using is the "if you had money" thing is silly....because if you read this board at all, you'd see that nobody has money, and if they do have it, they spend it elsewhere.
You have no idea how much **** i had to go through to teach these people that dropzone coilovers on stock struts without an alignment "isn't good handling".
-93 MR2
#129 E-stock
Steeb
Post by Steeb »
a coilover kit offers a damper that is tuned to the spring rates at which the coilover is offered (supposedly). true you dont need a fully adjustable coilover to get a tunable damper but it has its advantages and disadvantages over mix and match setups. what is stopping someone with a regular spring and strut setup from corner weighting?
<small>[ December 31, 2003, 04:12 AM: Message edited by: Steeb ]</small>
Steeb
Post by Steeb »
the coilovers in this thread are hayame. they are made with a tokico adjustable strut and are servicable. thats what i am told anyway. can you not use spacers to cornerweight?
mazdubber
Post by mazdubber »
The reason I posted in this thread in the first place was to discourage the misuse of coilovers. Thats a very important purpose of these forums. Who knows, by posting here you may have saved a 16 year old from skidding into the back of a dumptruck because he had his coilovers bottomed out and the stock shocks were riding on the bump stops. :shrug:
92 GS
mazdubber
Post by mazdubber »
In order to change the corner weights you must be able to change the ride height. Spacers would not work as most vehicles have different spring sizes and rates front to back. When adjusting corner weights, whatever adjustments you make to one corner have to be matched with the opposite corner.
92 GS
Steeb
Post by Steeb »
i stand corrected. i argued with someone about this before. they convinced me that they were right and when i believed them, im posting wrong info. sorry.
<small>[ December 31, 2003, 04:15 PM: Message edited by: Steeb ]</small>
Post by Josh »
there is a French web page of someones mx. and he has listed a set of real coilovers and pics of the coilovers that he had gotten. he also has some sweet rear mudflaps but i dont speek french and i didnt have a good enough english to french converter, so my email was never awnsered.
nope-mx3
Post by nope-mx3 »
I know for a fact that it`s a company in Germany named K.A.W that makes a real adjustable coiloverkit.
It`s about $1540 USD before refund if you give them your 4 original struts.
nope-mx3
marcdh
Post by marcdh »
anyone tried these? I've done a search - which implies toser coilovers are not available...yet this company claims they have MX 3 toser coilovers -$1100
http://www.racingmazda.com/mx3-suspension.htm
View Worklog
Custommx3
Site Administrator
Post by Custommx3 »
This topic is OLD!
