Well thanks, kind of surprised you're actually giving me credit for once. Still weird having you call me by my first name.MrMazda92 wrote:I'm picking through your worklog Igor, and you've got a clean looking build going. We don't always get along, but I'll admit you've done a hell of a job on the car.
_-Night-Shade-_ [ 1994 GS-R ] - Winter 2012 ... Part 1
- _-Night-Shade-_
Re: _-Night-Shade-_ [ 1994 GS-R ] - Winter / Drag racing vid
Lol don't hate on PT, they know their stuff over there. A lot more resources and information over there than here I'd say.
- MrMazda92
Some of them really do know a lot, it's just more chock full of misinformation than most forums... Their membership pool is broad enough that information can be attained easily, but I've never seen so many examples of "well so and so said, so it must be true" than PT.
Still, there is good information to be found if you can verify it before trying it.
I don't always agree with you, but I can respect quality work and a clean car. I don't have to if you prefer I don't; I typically use members' names when I remember them.
- jschrauwen
Re: _-Night-Shade-_ [ 1994 GS-R ] - Winter 2010/2011
Looks great. I hope you got overdrive pulleys for the waterpump, alternator and power steering pump so as to retain oem output from those ancilliaries when at idle/low speeds?
_-Night-Shade-_ wrote:Stock crank pulley vs. Unorthodox Racing crank pulley. The stock one weighs 4.8lbs and the Unorthodox is too light for my scale to pick up, definitely under 1lbs, so that's a few more pounds of rotating mass shaved off in addition to the flywheel.
- jschrauwen
Maybe it's time for a KLZE LSD transmission?
BTW, I just went through all 16 pages - great thread!!!
_-Night-Shade-_ wrote:It's a PGT transmission, we already verified it with the VIN on the housing way back when the swap happened. The fidanza is used. The clutch didn't appear to be bowl shaped. It's just a crappy clutch. It's a Valeo. And yes I cleaned the flywheel and everything nicely before putting it back together. I'm not sure if you read the description on YouTube but my VRIS #1 wasn't working at the time, that plus the clutch is the reason why the acceleration wasn't what it should be. The revs are slightly lower but not as low as they would be with an MX-6 transmission. My times were horrible, 15.2 (which is worse than just a plain KLZE swap never mind bolt ons!) was the best I got and all my 60ft were 2.5s. I did 9 runs and every time I tried something different. Just having to slip the clutch while launching hard already made it slip more when shifting. But if I shifted slower or didn't launch as hard I'd get a slow time anyway... Oh well, next season.
- _-Night-Shade-_
Thanks John. It means a lot coming from a veteran MX-3er such as yourselfjschrauwen wrote:BTW, I just went through all 16 pages - great thread!!!
To answer your question about the pulley, the whole point of that mod is to NOT maintain OEM output. You recover lost power by reducing the drive to the accessories. If I threw on overdrive pulleys for all the accessories I'd be right back where I started, just with a cooler looking pulley and slight weight reduction. Oh and for anybody wondering - I have my battery in the trunk but I didn't have it bolted down securely at the time of this incident, only bungee corded to keep it in place. Anyways I was late for something so I was driving pretty aggressively and I took this one corner really fast and all I heard is a *THUD* I looked behind me and my battery tipped over, slid and had broken itself free from the cord and got disconnected (it's a sealed AGM so nothing happened). However this just goes to show you how well Unorthodox engineers their stuff (and how much of a safe margin there is with the OEM Mazda pulley output): I had enough power with the Unorthodox UP and just my alternator (stock alternator) to idle at a red light, make it to where I was going, and park. As for the rest - the steering will feel identical with it (if there's guys converting to manual racks and not having a problem you can see what I mean). And there are no overheating issues, in fact it may warm up slightly faster and if you're not doing a lot of moving the rad fan might kick in a little bit more frequently, but that's not a downside by any means. So there you go guys, doing some accidental testing so you don't have to
As for the JDM LSD - the only issues I have with it are that if it's a KLZE LSD it will have the MX-6 4.11 final drive. And even though you can take it apart, swap it out to the higher final drive, there is still the problem of getting axles for it...
In reality, you only need the battery the start the car. Although the alternator should charge around 14.4ish volts, you're car would easilly run even if the UDP only charged it at 12v at idle (my truck charges at 12.5v sometimes when she's idling at 500rpm - marine alternator). Even then, you should be able to safely drive around pulling down to around 10.5v_-Night-Shade-_ wrote:my battery tipped over, slid and had broken itself free from the cord and got disconnected [...] I had enough power with the Unorthodox UP and just my alternator (stock alternator) to idle at a red light, make it to where I was going, and park.
- _-Night-Shade-_
ExactlyNd4SpdSe wrote:In reality, you only need the battery the start the car. Although the alternator should charge around 14.4ish volts, you're car would easilly run even if the UDP only charged it at 12v at idle (my truck charges at 12.5v sometimes when she's idling at 500rpm - marine alternator). Even then, you should be able to safely drive around pulling down to around 10.5v_-Night-Shade-_ wrote:my battery tipped over, slid and had broken itself free from the cord and got disconnected [...] I had enough power with the Unorthodox UP and just my alternator (stock alternator) to idle at a red light, make it to where I was going, and park.
People get too carried away and exaggerate the false fears of using a UDP.
- MrMazda92
I agree on the alternator, but the waterpump is of more concern to me... If I planned to use a UDP, I would overdrive that, at the very least. Still, I prefer complete removal of unused accessories.
- _-Night-Shade-_
Well if anyone's that paranoid about the cooling system, why not upgrade to a thicker all-aluminum rad, stronger fans, etc. Why take a step backward when you can take a step forward?MrMazda92 wrote:I agree on the alternator, but the waterpump is of more concern to me... If I planned to use a UDP, I would overdrive that, at the very least. Still, I prefer complete removal of unused accessories.
- _-Night-Shade-_
Transporting my MX-3 to the new workspace for the winter, VIP style...
The new workspace:
Those KDWs sure leave a sexy footprint
All washed and sparkly clean
Soon... the fun will begin
Stay tuned for Part 2
The new workspace:
- MrMazda92
For what it's worth, I already have an upgraded radiator._-Night-Shade-_ wrote:Well if anyone's that paranoid about the cooling system, why not upgrade to a thicker all-aluminum rad, stronger fans, etc. Why take a step backward when you can take a step forward?MrMazda92 wrote:I agree on the alternator, but the waterpump is of more concern to me... If I planned to use a UDP, I would overdrive that, at the very least. Still, I prefer complete removal of unused accessories.
- _-Night-Shade-_
That's good. Maybe paranoid wasn't the right word to use, what I was getting at is I don't see the point of fixing something that isn't an issue. Like I said, I'm running the Unorthodox UDP with a stock water pump, stock rad, stock fan, and have no overheating issues.MrMazda92 wrote:For what it's worth, I already have an upgraded radiator.Not paranoid, just cautious. Oil starvation and overheating are the 2 main causes of engine death. Well, the true "cause" is lack of maintenance, but those are the usual culprits from a mechanical standpoint.
- MrMazda92
Re: _-Night-Shade-_ [ 1994 GS-R ] - Winter 2012 ... Part 1
I can respect that. You don't live in a super hot climate do you? I don't know Canadian climates very well at all... All I've ever heard is cold throughout.
I'm sure you'll keep an eye on it too, no? I think I remember you having multiple temp gauges anyways. I'm curious as to what your part 2 winter plans will hold, looks like something big is coming!
- _-Night-Shade-_
LOL I'm not surprised, everyone (k not everyone but ya know what I mean) in the states thinks Canadians live in igloos.MrMazda92 wrote:I don't know Canadian climates very well at all... All I've ever heard is cold throughout.
The climate here in Toronto is... f'ed up to say the least. Cold winters, hot summers. But this year we've actually had a really mild winter, barely any snow and often hovering above 0*C (hence why I washed my car). Haven't even really had to use the 4x4 in my truck, just driving in RWD. But they're still salting the roads like crazy so winter driving the MX-3 is a big no no.MrMazda92 wrote:I can respect that. You don't live in a super hot climate do you?
HUGE! It's gonna catch everyone by surprise! Hahah I hope...MrMazda92 wrote:I'm curious as to what your part 2 winter plans will hold, looks like something big is coming!
I don't think you live in igloos. I think you live in a little log cabin by a frozen lake, and you sit by a hole cut in the ice fishing all day._-Night-Shade-_ wrote: LOL I'm not surprised, everyone (k not everyone but ya know what I mean) in the states thinks Canadians live in igloos.
