Page 14 of 16
Re: weede`s KL-ZE Supercharger - Megasquirt
Posted: April 25th, 2013, 7:17 pm
by mx3matt
amazing job on the outlet, but i still think you should clearance the lower rad support.
Posted: April 26th, 2013, 8:04 pm
by Thefez
I absolutly love this car with a passion truly one of my favorite MX-3's on this site...
where did u get that piller with the pod?
Posted: April 28th, 2013, 6:00 am
by weede_klze
youdirtyfox wrote:Will that not contact during engine movement?
if will , i can take off some of material
BTW
i relocated power steering cooler (will be intercooler instead) and fit much bigger cooler from mazda 626
![Image](http://img560.imageshack.us/img560/1123/wspomaganiep.jpg)
Posted: June 2nd, 2013, 12:15 pm
by weede_klze
custom made water cooler (two times wider and 10cm less than stockk)
Intercooler on board
i want keep sleeper style
mooore coolers
![Image](http://img62.imageshack.us/img62/2294/ic2v.jpg)
Posted: June 2nd, 2013, 1:34 pm
by kulluminati777
lol your power steering fluid gets that hot. I want to do the same but use it as an oil cooler. You said you got it from a 626? Or is it an aftermarket thing. did you cut the chassis any or it all fit behind the bumper just fine? Does look good BTW
Posted: June 2nd, 2013, 5:23 pm
by weede_klze
no i dont want to cut chassie - only bumper was cut. Power steering cooler is OEM Mazda from 626 but i dont remeber witch one. Of course this power steering cooler is little exaggerated but why not
Posted: October 16th, 2013, 9:48 pm
by Thefez
any updates on this man?
Posted: October 17th, 2013, 4:09 pm
by weede_klze
unfortunately, the engine was broke
One night two ZE retainer cracked and when my friend started to fix it I saw little marks on bearings causes of lack oil...So i now finish rebuild engine with KLDE valves/retainer (much stronger than ZE) and with reconfigurated oil relocation kit. I hope it will help, i lost this season
Posted: March 17th, 2014, 6:47 pm
by posey92
Love the supercharger...ill be doing the same but I have an M90 from the Ford Superbird. Havnt done the math yet. But im all about the budget. Ill figure out what ratio to get what psi I want then find some cam gears at the yard the size I need. Instant cog drive. No chamce of slipping.
Posted: March 26th, 2014, 12:27 pm
by Nd4SpdSe
M90 is pretty big...
Posted: March 28th, 2014, 7:57 pm
by weede_klze
M90 only in battery place
Posted: March 31st, 2014, 5:02 pm
by Nd4SpdSe
Even then, just for it's capacity, it's for a larger motor, 3.0 to 5.0L. My truck is a 3.3 with an M62
Posted: April 17th, 2014, 4:51 pm
by weede_klze
Car back on street
![Image](http://www.srtb.pl/mazda/sucz.jpg)
I have intaled KLDE retainers and springs.
![Image](http://www.srtb.pl/mazda/czesci_wiosna.jpg)
Spring Set:)
- new gear selector
- OEM rubbers and screws for gear selector
- 10W60 Oil + OEM filter
- poli on the back
- SACHS cover for struds
![Image](http://www.srtb.pl/mazda/amorki.jpg)
Rear Tokico HP struds.
I thing i dont send this photo...Air filter for Supercharger
![Image](http://www.srtb.pl/mazda/done_2.jpg)
Posted: April 18th, 2014, 12:26 am
by kulluminati777
YESSSS!!!!!!!! very cool i love its back on the road. What intake is that? I want to use a straight neck as well but im not 100% sure I want to relocated the battery just yet....
Posted: April 26th, 2014, 8:01 pm
by Thefez
would love to see some pics of the supercharger set up here how everythings installed
