i don't seem to understand how this thing quite works, what are the 3 small tubes coming from the reservoir?
i assume one is the overflow tube just in case the reservoir starts overflowing or whatever
there is only two small tubes onto the reservoir, one is the overflow yes thats built in to the neck/cap assembly, the other is the expansion feed from the rad.
the other small tube you can see goes down and connects to the alu. elbow connected to the air filter.
For the moment the ribbed section is staying like it is, but obviously when I turbo yes that section will be replaced with a nice lime green 2.5" 45 degree silicon elbow leading onto a straight 2.5" alu. pipe wich tapers gently down to 1.75"(I think) to meet the intercooler pipe poking round the side of the rad.
Nice wheels. What's the offset? My 16x8's have a +10 offset and just work with the camber option that I have in my coilovers. (well they "just work" after the fenders are rolled .)
Received my newly painter rocker cover from Paul (mx3gulf)
this morning, more than impressed with his great work on this, and tbh I wasnt expecting anything else.
Wil have to wait a week or so to fit it as I promised myself a little break
from any work
