[WTB] - 7 Post Distributor Cap
Re: [WTB] - 7 Post Distributor Cap
Yes, but I use an external coil out of a mustang and am using an MSD Ignition module... So I'm not sure if the disty without coil plays well with the original computer or not. I run the wire that would usually fire the disty's ignition to the external coil and then set up the MSD which takes over for the rotor.
How much is it through your dealership, I tried at work and no-go state side to order one inRogueWolf wrote:I grabbed one off of the UK Ebay. Fit perfectly. It's an OEM, HEI mod.
The cap is still being produced by Mazda, I only now found out that I could have ordered it directly from my local Mazda Dealership... because it's not for a North American car they will not accept returns on the part if it doesn't work. (At least my local dealership will.)
Just some info for anyone else out there, I picked one up and it will not fit a DE disty even with the coil removed, bolt holes on the caps are in different positions.RogueWolf wrote:I grabbed one off of the UK Ebay. Fit perfectly. It's an OEM, HEI mod.
