Page 2 of 2
Re: intake manifold
Posted: December 18th, 2012, 7:28 pm
by sinix3
i have a gs so yeah first kl haha. looking forward to alll the extra power and not burning oil XP
Re: intake manifold
Posted: December 26th, 2012, 3:02 pm
by sinix3
so seems how my millenia intake is missing pieces im thinking about just using my k8 intake until i can find a klze or fix the millenia intake. any ideas or should i just fix the millenia intake before starting my swap. i could use some help figuring out the vris electronics if anyone has some idea
Re: intake manifold
Posted: December 26th, 2012, 5:13 pm
by Nd4SpdSe
Missing pieces?
Re: intake manifold
Posted: December 26th, 2012, 9:28 pm
by sinix3
It is missing the solenoids for the Chris and one of the vacuum valves like the vacuum part that opens the valve. I fabricated one of them up but idk about the solenoids
Re: intake manifold
Posted: December 26th, 2012, 11:25 pm
by Nd4SpdSe
Should be interchangeable from all intake manifolds, including the K8
Re: intake manifold
Posted: December 27th, 2012, 12:25 pm
by sinix3
ok i just have to figure out the vacume routing then. would you happen to know where i can get a diagram for that?
Re: intake manifold
Posted: December 27th, 2012, 12:50 pm
by Nd4SpdSe
Re: intake manifold
Posted: December 27th, 2012, 9:28 pm
by crazycanadian
The solenoids them selves are interchangeable...
Re: intake manifold
Posted: December 29th, 2012, 6:26 pm
by sinix3
you wouldnt happen to have a k8 vacuum diagram aswell would you?
Re: intake manifold
Posted: December 29th, 2012, 7:52 pm
by sinix3
and do you know if i can use the millenia egr or do i have to use the k8?
Re: intake manifold
Posted: December 29th, 2012, 11:45 pm
by MrMazda92
The EGR will not swap over, unfortunately.
I have a K8 IM and EGR I could part with. ;D
Re: intake manifold
Posted: December 30th, 2012, 1:03 am
by crazycanadian
I might still have my KLDE egr valve in a box some where...
Re: intake manifold
Posted: December 30th, 2012, 11:27 pm
by sinix3
No i have a k8 intake and exhaust and egr lol i started te swap today. I just put a little plate over the egr on the intake and will leave the age bolted to the block so i dont get any ce codes. Wish me luck. Tomorrow i start plugging everything in and fire it up
Re: intake manifold
Posted: January 4th, 2013, 5:35 pm
by Nd4SpdSe
viewtopic.php?f=2&t=80489
-4- VRIS Solenoids, i have 2 of these 15 each
-5- EGR Solenoid w/bracket 5
