Traction bars --- KL & BP
- Ryan
Re: Traction bars --- KL & BP
I know how it works, the connection swivels, thats fine, but the thing I was assuming, was that the connection on the new subframe was not exactly in line with the LCA rotational axis. If it is, then you're good.
Both sides are in axis to the LCA's swing.
Cone spacers are provided instead of tube stock @ the heim joints- this allows for more pivot angle for the heim joints.
Given both ends are inline & both utilize cone spacers you could theoretically max out one side for pivot & still have some angle left on the opposing side. Thats the beauty of it
- kulluminati777
the mazdaspeed mx-3 may need a set of these...are they only beneficial for straight line speed or is there more...
- Ryan
They'd help with undesired toe changes under any hard acceleration, straight or corners.
jamestakay
If I have enough funds after my swap, I maybe looking at these if you come up with more in the future. Kind of running low on funds for the moment. lol
2- shipped out today!!
2 LEFT!!!!
here are better pictures showing where the bars mount.
the LCA's are a multi-layer stamped steel piece. the bottom hole & middle hole(from the bottom going up) must be slightly enlarged to match that of the upper hole ( M12 bolt size ) easily done with a drill/grinding bit in a matter of minutes
Per the obvious. these pictures were taken during R&D - with incomplete bracketry.
-Ryan
2 LEFT!!!!
-Ryan
1 Left unspoken for.......
It appears these are the latest craze!!!
- diezzel
Thank you kindly . Will be in touch .
- MrMazda92
I hope you will make more down the road, maybe in 3 months or so??
Since engines are consistently expensive to build, I can rely on the price for parts and labor being high
That being said, it's suspension overhaul time!
I'm springing for everything...
As of now these are a limited run.
Each of these were put together using my old GS as a jig. - perfectly straight GS frame -
Shortly, finding un-bent/ un-twisted/ un-mangled mx3 tow hooks to use is also a severe challenge.
now in the event im given or acquire more tow hooks in good shape.
I could attempt to coax the new owner of my old car into letting me borrow it for test & building purposes.
End point. its fuzzy right now as to if there will be more made......
- MrMazda92
You use towhooks for the brackets?
Would you be able to find a local machine shop that could produce 20 or 30 sets for a reasonable rate? I imagine it wouldn't be too hard... I would volunteer the use of my towhook as a template, assuming I could get it back in one piece.
That would reduce costs quite a bit for you, especially since towhooks require a lot of time/effort to source, in sufficient quantity at least.
Producing new towhooks could be done theoretically.
But the production cost of cutting & bending said pieces would heavily outweigh on the cost to provide these.
The LCA brackets were waterjet cut & bent locally. so i have the ability.....
I bent each of the bars @ my current work (luckily enough to have access to a good pipe bender) this was my time & labor (which you can't really outsource from another shop cheaper)
However, i won't be working there for much longer. I'll be moving across country
My boss would be keen toward making more-- but would need to design a Jig of some sort in order to do so.
Wherein again lies the problem of sourcing a perfectly straight mx3 frame
Look @ the pictures on the first page again you'll have a better understanding of whats going on.
- MrMazda92
Alright, thats a little beyond me sadly...
If I can help in any way, please let me know.
I would LOVE a chance to buy these, but I can't currently
time will tell in terms of a 2nd batch....
- MrMazda92
I'll be waiting impatiently!
