mikeetown wrote:Nd4Speed said that it doesnt brake good
Here's the reference:
http://www.insideline.com/features/1998 ... ic-si.html
My Mx-3 with the PBR pads braked awesome. Had cross-drilled and slotted rotors, but not sure if that helped. Getting the cheapies at your local parts store will of course not brake that well. Given the age of the car, that's probably what most Mx-3's have on them.
mikeetown wrote:It doesnt matter if u have a ZE, DE, this newer car with this great technology in the right hands, is frikin aweosmely fast.
Absolutely, alot has changed in 20 years. But you weren't talking about the technology, you were saying that an SI would be faster than a ZE Mx-3, it's not, but of course new cars will have more potential; it's pretty much a given.
mikeetown wrote:Its retarded how good the computers and brakes in the new SI is. frik! i want twin piston brakes.
It's not really the computer, it's the engine. The manufacturers (Honda in thise case) actually limit the power through the computer because of how much potential the motor has. It''s not the computer that's doing it, but you can thank those that hacked the Honda ECM.
An Mx-3 doesn't need twin piston brakes, or a big brake kit. As long as you're braking system is working good, you've got some good lines, performance pads and rotors, maybe go to Dot4 and you're all set. It doesn't matter how many pistons you have, it's the pads and rotors that do the braking.
