HAHAHAcarizle wrote:I love when n00bs get mad and try to argue with someone that has built an AWD MX-3. Freakin AWD! Not that I'm not a n00b myselfjcallaway86 wrote:Disregarding the flamer....Jeez show some respect at least. Anyway, I wouldn't even touch an rs 4 knocker without the intentions of swapping a b6t, bpt or whatever other appropriate swap; my K8 is slow enough as it is.
Over the coarse of 9 years i have probably blown 20K on my car with all the different swaps and mods doing all the work myself, alot of trial and error. i know first hand from countless hours of researching. And i dont know it all by any means, but what i do know is B6 and BP blocks.
If you want NA power out of your B6 i strongly recommend sourcing a mid 80's SOHC 8 valve head, still would have to block the oil ports but this SOHC 2 valve per cylinder head flows more air than its 4 valve cousins. And would sound amazing, this would be the head to put ITB's on. I have dreamt of doing a miata build with this setup but alas... it is but a dream.
