Josh's AWD Worklog
- MrMazda92
Re: Josh's AWD Worklog (finally)
1) How much weight does the AWD setup add? Approximately at least, doesn't need to be exact.
2) I'm a V6 man, but that engine is so clean I had to search around on my floor for my jaw.
3) Any chance I can get the exact dimensions of your stainless door sills? Is that a carbon fiber door sill? Looked like one, but that might be my eyes...
4) Welcome back. Good man, don't let the man keep you down!! Also, I hope you skinned the guy who ripped you off.
- bbunkerc397
If I'm not mistaken that looks like a Mazda 929 rear diff with some sort of mod to the rear K-member. What transmission are you using?
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
- AaronTietje
More pics of this build would def. make my day.
This is a very Hi-Quality build---big thumbs up.
- Josh
its actually the rear end from a 91' AWD Protege, the trans is from a GTR. i will eventually get a forged gear set for it but for now it will be ok.
so i decidecd to to with a 16G Subi turbo, i will upgrade to the 20G later on next year, mainly they are cheep, they make alot of power, they are inturnaly waistgated, and they are both oil and water cooled. all i need to do is fab it up and mount it, fab up my exhaust wich is full 3" SS and doing a seperate 1.75" waistgate run on the Down Pipe, install my stand alone, and get my BP intake flange welded to my aluminium intake mani and she will be on the road once again. check back in January for updates, as i should have it driving and tuned by then. Hopefully i can cut back the fuel enough on the 750cc injectors i have for my little Turbo... it should be good for about 350ish WHP we will have to see.
Thanks for checking in
Josh wrote:so i decidecd to to with a 16G Subi turbo, i will upgrade to the 20G later on next year, mainly they are cheep, they make alot of power, they are internally wastegated, and they are both oil and water cooled. all i need to do is fab it up and mount it, fab up my exhaust which is full 3" SS and doing a seperate 1.75" wastegate run on the Down Pipe, install my stand alone, and get my BP intake flange welded to my aluminum intake mani and she will be on the road once again. check back in January for updates, as i should have it driving and tuned by then. Hopefully i can cut back the fuel enough on the 750cc injectors i have for my little Turbo... it should be good for about 350ish WHP we will have to see.
hi buddy..
do you have another worklog that has the AWD Conversion part better described?..
i have a somewhat similar plan for my GS, and seeing you put a diff in the back, cought my attention immediatly..
tnx
tnx
memberlist.php?mode=viewprofile&u=2713Josh
95 AWD RST
https://home.comcast.net/~josh95mx/index.html http://www.cardomain.com/ride/408020
AWD FINALLY DONE!!!!!
"Search Users Posts"
viewtopic.php?f=19&t=69972
viewtopic.php?f=3&t=64730
viewtopic.php?f=3&t=63085
viewtopic.php?f=3&t=59272
viewtopic.php?f=17&t=55619
viewtopic.php?f=21&t=53920
viewtopic.php?f=3&t=52137
viewtopic.php?f=22&t=46093
viewtopic.php?f=20&t=49196
viewtopic.php?f=21&t=45405
viewtopic.php?f=3&t=47984
viewtopic.php?f=1&t=45380
viewtopic.php?f=3&t=37434
Man impressive, what more can I say. AWD is definitely bigger then a ZE mod and a hell of a lot more challenging. No probs with traction now eh.
So are you rotary or fixed wing trained?
- Josh
Rotary trained. I think its the way to go.Daninski wrote:Man impressive, what more can I say. AWD is definitely bigger then a ZE mod and a hell of a lot more challenging. No probs with traction now eh.So are you rotary or fixed wing trained?
I will get some more pics up real soon, im remounting the rear diff, and re running the driveshaft so i can fit a full 3" exhaust. Lots to do on it, I have decided to pull the motor and re-fab my motor mounts front and rear as well as pollyfill everything. I should just solid mount it.
- carizle
nice job josh i'd just like to see some more info on what kind of fabrication might have been necessary to fit the rear end. oh and i'm starting to get the urge to ditch my gs for a four banger so i can bp-t it some day
If it weren't for physics and law enforcement, I'd be unstoppable!
98 Mustang Gt-convertible, bolt-ons and SCT race tune-Cams and 4.10 gears coming soon
SOLD-92 GS beater-280,000 miles and still goin strong-HEI mod
SOLD-91 Explorer XLT 4x4-never let me down, at least when I can afford to fill it up
That's it! I4s boosted are just too much fun!!!
Drag spoiler all the way. No two spoilers on the same azz end. That is just . . . well. . . I'll say it. . . rice.
Nice to see someone wanting to do an awd setup with this platform. I come from T/E/Ls and I can 'tell' you, if my tranny holds, it's like cheating.
- Josh
I really like the drag spoiler to, just the MS spoiler is just sweet due to its MazdaSpeed, and i like the lip, it accents it. But I think im going to do two hatches. One for everyday and the other for the track. and im thinking instead of glass im going to run just the louver hatch. Weird i know but i really what to see it.wheelhop wrote:That's it! I4s boosted are just too much fun!!!
I will do a full write up on the AWD swap later on this spring. Im redoing the entire thing as i did it kinda half a$$ed IMO. its got to be showable and look OEM. i have to raise the rear strut perches so i can get more travle in my struts and im going to a 2 piece drive shaft instead of the 3 piece i was using out of the Protege. Its comming along well, im hopwing to be done in the next couple of months.
- Josh
Josh's AWD Worklog update 6/7/11
Here is how i moded the rear frame rails. I drilled out the spot welds on the Protege rails and channeled them, then spot welded them to the MX3 rails. It was quick and half a-- way of doing it. I am now fabing up custom rails mounting the rear end into the chassis higher by about 3".
couple of updates: New suspension is almost done, have to finish the fronts now
Here is what the intake mani looks like, have to weld the BP flange to it, and its done!
Yes, its a Egay SS turbo mani that I rewelded with a subi flange with a 16G. This is what i have been up to as of late. I have most of the piping done for the DP just one more piece to cut and then to add the Waist Gate piping. I was going to tie it into the 3" DP but almost thinking i should just do a dump... hmm
just a engine cradle pic, if you look you can see my rear motor mount that I made out of a trailing arm
- Josh
Re: Josh's AWD Worklog updated 6/27/11
some more pics of the suspension set up after paint and installed..
Turbo Downpipe mostly completed. Have to finish it off with a separate 2" waistgate pipe running along side.
If i didn't have the center diff for the AWD it would have been a bit easier, but it is snugged in tightly, as it has to because of the driveline running down the tunnel. I should widen it, but... I don't really want to.
- Vecia
Re: Josh's AWD Worklog updated 6/27/11 more pic's added
This car is amazing. Nice work, man.
