93 1.8 boggin and buckin
Re: 93 1.8 boggin and buckin
And before you say that the light only flickers, or is rarely on, check for codes anyway.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
hey I got a buddy with a 1.8 v6.... He somewhat had the same problem.... we put another Distributor in it and it worked alot better...
this is what i would do:
1) check for codes... Read FAQ on how to. Then let us know
2) Change the distributor (if u got the coin)
3) Let ur car warm up and unplug the IAC plug... (under the throtle body) see what happens... let us know
4) check ur connections to sensors dizzy cap etc...
